Question???
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Sammy~D said:
where can i get a turbo or supercharger
Wow. :oogle: Not for nothing, but I HIGHLY suggest you either rephrase that, or ask a different question. You'll find out soon enough why.
To (try and) answer your question. . . if you looking for a cheap used turbo/supercharger that you'd want to rebuild or slap it on just like that, ebay's your friend. Or you can do a search for all the blown/turbo guys, and ask how did went about getting theirs. Good luck!
Sammy~D
Wrench Whore
Anoka, Minnesota
ok where can i buy a turbo set up supercharger set up......or how would i about making the set up my self???
SonicRiot
Handbanana!
CT
I have 2 K-16-2s that would make a pretty nasty bi-turbo setup...:evilgrin:
TYSHO
Earth
Nice set up there, Doug! :thumb:
After seeing that picture a few times, I just noticed there's not a BOV visable. Do your kits come with one or without?
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
I use a Vortech Racing Bypass valve that recirculates bypassed boost pressure back into the supercharger intake. The valve is located on the bottom of the discharge pipe and exhausts back into the inlet pipe. In the picture, you can see where it connects to the inlet pipe.
Photo 090105 003
Because I have the MAF in the fender for proper tuning, you can't vent boost to the atmosphere. It must be recirculated.
Here's a couple more shots...
Photo 062105 010
Photo 061405 011
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Basic BYOT (Bring Your Own Tuning) kit starts at $4500. That's blower, brackets, belt drive, shaft drive bypass and plumbing.
Upgrade kit includes injectors, MAF, chip, tuning and fuel system for abotu $2000. Installation in our shop is $1000.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Ever tried it? My BOV vents to the atmoshpere and has never been a problem. That said, on my next project, I hope to either have a BTM or a bypass valve. If I still have to use a BOV post MAF though, I am not concerned. Do you use the bypass valve as a boost controller as well?
yamahaSHO
E85 whore
Arkansas
Tim, you can't do it with a supercharger like you can a turbo. When you close the throttle, you reduce the load to the turbo. When you do the same to the SC, it's still spinning according to engine RPM. This would cause you to run EXTREMELY rich. In fact, so rich that the computer completely stops learning and applying KAM's. I've had this happen to me several times when I had my MAF pre-blower.
