Question
2tochoose
Delafield,WI
I am looking at buying another SHO a 98 to be exact the only problem with the car is it needs balljoints and a right outer tierod and a left inner tierod. How much work are those to fix and about how much would it cost?
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
Unless you can do these yourself, I would guess those repairs, including parts may run north of $500. To replace balljoints, they need to be removed completely from the knuckle, so it may be cheaper (save on labor) to just replace the whole knuckle.
nothingtoseehere
Replaced the knuckles on mine, was only like 45 per side with the ball joint, of course no labor charge, just parts, but not an overly difficult job
EHBOY
Boston, MA and Derry, NH (near Salem)
I second that... i just replaced my whole knuckle on both sides... hardest part was separating the balljoint from the control arm... just use a large pry bar and WHACK the end of the control arm with a 2.5 lb short handled sledge... Sucker will pop right out!
Firespirit
Indiana SLO
Michigan City, IN
If you can't or are unable to install them yourself here's a price -
My '97 GL needed an outer tie rod and ball joint (from a previous accident) I ended up paying somewhere like $210 for the ball joint and $150 for the tie rod.
I wish I would have done it myself, but there's no tools or room here for all that :(
Mr. SHO
Philadelphia
If you are handy with tools, the inner & outer tie rods aren't too hard. You will want to replace both sides, inners and outers. It took me under 3 hours to do the job and it was the first time I've ever done that job. Not really too difficult. You will NEED a special tool for the inner tie rods. Some people use vice grips, but there is no way to properly torque the inner tie rod end without using the $50 tool.
The knuckles will be a little more difficult, but a shop will probably only charge about 3 hours labor for both sides. Mine are getting done right now. :biggrin:
