Mark in PDX
I have a black 89 w/135k on it. I am doing the Valve shim this weekend.
I just had the cps/ckps, evr, plugs,wires and have had the waterpump replaced and o2 sensors.
The car also blew it's cats apart because of the evr and o2' so it has new catalytics on it now.
I noticed that the car seems to have a huge amount of moisture come out of the car in the mornings. When I put the car on jack stands, water practically ran out of the exhaust...
I had a ford dealer do the work on the ever/o2/cps/ckps etc, they also replaced the valve covers and cleared the codes. I checked and I am clear on codes.
My question, Could I have a blown or leaking head gasket? I note that every time I run teh car I have to put more water in the overflow resevoir. If I don't the light is on when I start the car, and it goes off as the car warms up. Stop the car let it sit overnite and the 'water low' is on when I start the car in the morning. I don't SEE any leaks in the water bottle or radiator.
Could the water be from the bad cats? and poor running it has had? I am going to be driving it quite a bit over the next week. It has been sitting more than driving up to this point.
Hints as to what I should be worried about? Things I can check while I have it torn apart this weekend?
