Question about turbo.
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
Does anyone have a partslist of what the have to make a turbo SHO.
I know the basics like, Turbo, Piping, BOV, Wastegate.
But, What supporting mods will I need?
Jeff
60kmaintenance
U.S.A.
Tweecer, injectors, clutch, (to be safe, axles and tranny work), reinforced mounts, other things too. Those are just a few more.
SASHO91
Zoom Zoom
San Antonio,TX
falls under trany work, but either a quaife, or a reinforced diff....
probably a 9 puck clutch or greater...
Tweecer, or if you dont have that cash, an LPM, that is if you can get ahold of him...
brakes... deffiently brakes... if you havent allready...
fuel pump... 190 atleast.... and a FPR...
i can think of more.. but i will let others chime in....
60kmaintenance
U.S.A.
How about five thousand dollars worth of stuff basically, is what you will at least have into it, to be done right.
TT SHO PROJECT
OHIO
5 grand?!?! ack! lol i have 20 bucks into mine... then agian i only have 4k rpm of usefull powerband before i run outta fuel :p
60kmaintenance
U.S.A.
"Properly" install a turbo, like some thing they could actaully sell off a car lot :)
somedude_001
Western NY
look at it this way many cars only rev to 5500rpm so if you have 4K of power your still doing pretty good :rofl:
back on topic, I am in the parts collection stage and a while back I made this list to keep track of things for myself and to get some feedback on a few questions, its not perfect or a complete list but it a start.
http://www.superhighoutput.com/forum/index.php?act=ST&f=3&t=2264&st=0#entry19086
5K :laugh_ti:
SinisterSHO
Rust free
630, IL
Well, theoretically, you dont need any supporting mods. It just depends on how well you want the car to perform. That guy from North Carolina doesn't have many other mods and he seems to be doing okay. However, a stiff suspension and big brakes are going to help you handle the power better. And more engine mods are going to help you make more power.
But, all of this has been covered before.
NCTaurusSHO
Guest
Elizabeth City, NC
This is what I have on my turbo car. FMU, 30lb injectors, 73mm mass air, welded motor+trans mounts, and the custom crossover pipe.
TT SHO PROJECT
OHIO
i have a 12:1 fmu. stock injectors stock pump... stock maf... and well thats all. =P
oh yeah and my sorry atempt at weldiong the motor mounts... (hard todo with a 88amp welder and no argon)
60kmaintenance
U.S.A.
Doing any thing like this will ALWAYS end up costing more then you think.... Remmeber all the gaskets, and maintenance invovled. If you do not do it, and stuff a bunch more power in the engine.... Kiss your rod bearings good bye and other things.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
MI-SHOFEAR said:
I was thinking about the intercooler, but I wasnt sure how vidal it really was.
low boost does not require it. Most s/c SHOs do not have any charge cooling either. It will help but is not entirely necessary with low boost.
TT SHO PROJECT
OHIO
SuperchargedSHOguy said:
low boost does not require it. Most boosted SHOs do not have any charge cooling either. It will help but is not entirely necessary with low boost.
ok now whats "low boost" ??
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
In my opinion, low boost is under 8-9 psi whether it is SHOSHOP blower kit or home made turbo. If you want to run 12+ psi you need lots more supporting mods including the intercooler to run efficiently.
1slickRED89
Guest
Toledo Ohio
Jeff
jeff, email me, I can talk about an 'well done' ATX, but most parts may be the same for MTX. for me it really comes down to how much you want to impress. the 'oh ****' factor costs. but, as posted, it looks like one can have the basic parts welded/glued/screwed to the car for cheap.
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
I will be sure to get with you soon
