SHOwn the way
I heard that intrax springs sag after a year or two. I want the 1.5" front/1" rear drop the intrax provide, but if they sag... The eibach springs only lower about 1".
I'd have to agree with your opinion on the Eibach's. I was looking for a slight drop in the front and they turned out to be perfect. Combined with the Tokico's they give a perfect stiff and well responsive ride. A drop any lower than an inch in the front and you are going to have major issues getting a floor jack under the front air dam.billyshoe:
I think the Eibachs are OK. They will not lower the car much, but maybe enough. As already mentioned the rears tend to droop. The 3/4" inch drop that the Eibachs spec. may actually raise the rear to 3/4" below OEM spec. The fronts will drop about an inch. You will notice and totallly appriciate the handling difference right off. I think the Eibachs are a better spring for everyday driving than the others availiable.
