Question about modding?
DaSho97
Former Owner
Mass
so i just recently want to start modding my SHO this summer before the convention, etc. i was looking at k&n air filters, exhaust and possibly rims/ tires. right now my SHO is my daily and dont feel like modding it in the cold lol. so what are some mods that you guys have, also wondering if anyone had computer issues when adding the feature(for some reason my dad thinks what ever i add to the car engine wise itll f*** up the computer system.) thanks.
nothingtoseehere
Mine had:
26MM rear sway bar
ALSB
FSTB - powdercoated red
Powdercoated intake (red)
color matched vanity cover
trans-go shift kit
MSR-190 in gray 17"
red LED switches courtesy of Brad in NY (BabySHO on TCCA)
blue LED cluster
Mustang dual piston calipers
SS brake lines
Porterized intake
Sirius in drop down ashtray
Roush lowering springs
3rd cat delete
Flowmaster
99 Headlights
99 taillights
Tuner was next then I got rid of it
stephen newberg
Ladysmith, BC, Canada
Some modifications are easy and fast, others much more expensive and take longer. In the area of easy and fast with low cost, some form of cold air intake modification is a good first step. And possibly an under drive pulley change. After that, getting significantly more out of the engine starts getting harder and more expensive.
The handling via suspension changes is more easily addressed, and at less cost. Sub frame bushings, strut tower brace, different sway bars and such are all easy and fairly inexpensive, plus there are always wheels and tires, which can make a huge difference.
pax, smn
96blackSHO
Wrentham, MA
hey dasho if you want to meet up with me and ill help you figuar out what you should do just give me a call 508 364 0611
K-Dawg
Treasure Coast, FL
Are you wanting to modify it to achieve some benefit, or just so you can have a "mod" list?
IMO, the best mods for the Gen 3 are keeping it clean and well maintained, some aftermarket mufflers, transmission improvements, and tires.
DaSho97
Former Owner
Mass
I was hoping to get some performance benefit i was thinking about doing, k&n filter, tires, and exhaust mainly.
stephen newberg
There is very little to be gained easily in the exhaust system other than changing the sound. Never hurts to make the car breath more freely and make it cold air. Some form of Porterization is the way to go on that, though putting in a K&N cannot hurt. But this will hold better onto the horsepower and torque that the car comes with, but that otherwise is lost to hot and restricted air intake. Past that, suspension and tires are the major things you can do. Eventually, you can rework the programming if you want, a 'tune'. But K-Dawg has a good point in that good maintenance and upkeep are often the first way to think.
pax, smn
