Question about a new tick in the engine.
penders94SHO
eden prairie,mn
I own a 1994 MTX and a recently a tick has started to happed. My 1994 SHO 5sp has 128,000ish miles and there is no check engine light. So far I have replaced the: Water pump, Alternator, Battery, Serpentine belt, Wires,Plugs and Valve adjustment.
The tick from engine does not happen when the car is cold, only when the car starts to warn up. I can only hear the tick from the engine when the car is completly stopped. The tick is non-constant, and varies is the speed and sound the of the tick. The sound varies from a slow chugging like sound to very rapid/quick short tick. When I will have the car completly stopped sometimes there is no tick at all, other times there slow tick, other times there is a fast tick, yet sometimes the speed of the tick will change in speed e.g. the tick will start off like a slow chug like tick than right away after the that the will change to a fast short tick. I guess different way of describing this could be that tick will vary and and will change between slow and fast and fast and fast and slow the car is stopped. Also, The temp of the car is normal and never overheats.
What do you think could cause a tick like this? A radiator fan? A rod bearing maybe? or what do you think??
autobahnsho
SHO Victim
NY for now, WY for real
If I understand correctly, it happens AFTER you shut the car off.
If so, this is normal in many many cars-
Metal expands and contracts when it gets hot or cold. The metal in the block/ intake/ exhaust system gets heated up when you drive it. Then when it starts cooling off changes size slightly, and 'ticks'.
Metal (and concrete) changes so much with temperature that you see those huge bumps in bridges where they build room for it to expand/contract.
You can borrow (or buy, they're fairly cheap) a mechanic's stethoscope to see exactly where it's coming from, and make sure it's not happening with the car on and is something worth worrying about...
penders94SHO
eden prairie,mn
What I mean by when I say the car is stopped I mean like it is running and at a stop light or stop sign. The tick goes away after the car is turned off. Do you any idea of what the tick could be caused by?
penders94SHO
eden prairie,mn
wood_e said:
Unadjusted valve lash
At about 118,000 miles I had the valves adjected, new plugs,and wires done at Mike Courtneys Truck Service in Eden Prairie MN. Do you think the valves became unadjusted some how even tho I just had them adjected less than 10k miles ago??
ShadetreeSHOguy
Postwhore
Dallas, Ga
just an idea, how did your timing chain tensioners look when he did the valve adjustment? cause that sound you're describing sounds exactly like what mine's doing , and its my rear bank timing chain tensioner
penders94SHO
eden prairie,mn
I do not think I have ever had the timing chain tensionser ever looked at or changed. The only thing Mike Courtney did was the valve adjectment, plugs, and wires. Do you think the timing chain tensioners could cause the tick I described in the first post?
bgjohnson
iowa
could it be belt slap? sounds like that might be it and your belt is starting to become really loose. when was the last time it was replaced?
penders94SHO
eden prairie,mn
I had the Serpentine belt replaced like 500 miles ago. Is there a anthor belt that cause 'belt slap'? When looking at the engine the tick sounds like comes from the left/lower part of the engine.
yamahaSHO
E85 whore
Arkansas
There are 3 belts on an MTX motor. 2 drive belts(Alt/AC & PS/WP) and a timing belt. New belts stretch. If you have had both of them replaced and you have not tightened them, or checked the tension, then they can very well be loose.
penders94SHO
eden prairie,mn
yamahaSHO said:
Does the varying speed of the "tick" coincide with engine speed?
As far as I can tell, the tick only seems to only happen when the car is stopped. The tick seems not to follow the engine speed. Have any idea?
yamahaSHO
E85 whore
Arkansas
SHOblime said:
clutch fork? that might sound like more of a "rattle" than a "tick," but it's possible.
You would generally hear the bearing and not the fork itself.
bgjohnson
iowa
yeah sorry i meant the timing belt, duh stupid me. and here's another i idea i got while reshimming my valves. i noticed that there is a hydraulic tensioner on the camshaft chains, if that tensioner bleeds excesive pressure that could maybe cause what your hearing too.
penders94SHO
eden prairie,mn
Do you have any idea of how much a timing belt would cost to get fixed?
Cocoa,Florida
the belt it self is like $30-$60 labors gonna run you 3 hours usually...do it yourself its not really that hard...make sure you take out the finder well though
