putting and lack of power..help!
fenwayfan1
mansfield, CT
Hi, I have a 96 and it like putts when you drive, and the check engine light actually blinks! I have changed the spark plugs, rotated the coils and changed the fuel filter and it still runs like this, it starts and idles fine but it is putting and has little power, any ideas anyone its driving me crazy!!
Louie.M.:nut:
Ishodu
Get the codes checked first. That CE light is a sign. There is a chance it could be a bad coil too.
fenwayfan1
mansfield, CT
putting
thanks for the reply and i do got to check the coils and has anyone ever seen the engine light blinking? its odd..
Louie..:nut:
nik97
Mile high
A blinking MIL is an A code, usually a missfire. The reason it is blinking is to alert you that catalyst damage may result from the missfire. Most customers will put up with a MIL but a blinking one usually brings them to the service dept. sooner. Most likely a bad coil.
V8silverfrost
Virginia
Bad Coil
My CEL was on for a few weeks a while back. Then it started to blink. Checked the code and got cylinder #6 misfire. Changed that coil and now running as good as new.
I would check the code and change that particular coil.
fenwayfan1
mansfield, CT
bad coil or coil
Thanks for the replys and i guess the coils is my problem so does anyone know the easiest way to find out which is bad? do i need a code reader?
Louie
1993MTXSHO
Its a Taurus...
Jersey
my check engine light was blinking in my 98 F-150 and as posted above that usually is a misfire, ended up being coil pack num 1 being fried on my truck. So it only was running on 7 cylinders and thats would certainly cause a lack of power. Anyway go easy on it becasue when that light blinks thats bad, when its soild on you can drive it. But blinking, from what iv read in the owners manuel of my truck you shouldnt drive far becasue it could cause engine damage.
On the front you can pull the coil wire plug out while the engine is running and see if there is a change in how the engine idles.
poffffd
