Okay, I took out the pulley and it appears fine, although it doesn't turn very far. If I spin it a bit, it might turn about 3/4 rotation, then slow and stop. However, when I removed the center part (not sure what it's called, the cylinder which slides inside the bearing, and is almost an inch long), and went to put it back in, I discovered that it is slightly bent, so it only goes in i lined up properly. I checked out the other bearings on that belt too. Alternator makes a little "wh-wh" noise, but nothing really extreme, as with my old unit. The A/C compressor (which doesn't work anyways) turns fairly well.
Another note, when I pulled down the driveway to go back up into the garage (it's on a hill), in neutral and simply rolling down it, I noticed the idle was dipping occasionally. It would hold at about 1000 RPMs, then suddenly drop to about 800 and pause, then bounce back up. Could this be related? Or is it more likely my age old plugs/wires (5k on Autolites in front, ?k on Autloites in back, probably filled with oil)? They're going to be replaced in a little bit, with the Motorcraft plugs/wires, when I do the shims.
<small>[ January 29, 2003, 12:00 PM: Message edited by: rendyx ]</small>
