So the MTX uses two belts as opposed to one on the ATX, correct? I've dealt with the thicker belt that powers the alternator, A/C, and water pump many times on my red 94 as the alternator was chewing them up left and right. But after looking at the other skinnier belt that powers the power steering, it definitely has major cracking and is on its way out here soon enough. Question is, is it a similar set up to remove / replace? Is there a spring-loaded dummy pully somewhere that can be adjusted with an allen wrench, similar to how the other belt is removed?
