Pulled my codes
Stainless
Edmonton, AB
On an 1992 MTX here is what I got:
KOEO
542 Fuel Pump Secondary Circuit failure
214 CID Circuit Filure
KOER
536 BOO Circuit Failure
214 CID Circuit Failure
I have no power (I am asuming the exhaust or the cats spec. clank when I try WOT under 3000 RPM) What do these codes mean, and what can I do to fix them.
Stainless
Edmonton, AB
Sorry, There wasn't a CID Circuit Fail on my KOER test, I meant a 521 PSPS circuit did not change states. If PS has anything to do with power steering, did I mess up the goose test?
projectSHO89
SHOless In St L
Stainless:
Yes. You probably missed the turning of the steering wheel and you also missed the brake pedal during the dynamic response test. It takes some practice to get everything within the short test window of 10 seconds.
Steve
The 214 says that you need to replace the cylinder identification sensor. This sensor failure can cause ugly starting (backfiring) and engine stumbling while driving. The Wells F134 is available from AutoZone for $32.99. It is secured to the passenger end of the rear bank exhaust camshaft by two 5.5mm (7.32") bolts. You will have to relocate the power steering reservoir (upward - tie it off to the hood strut) to access the bolts.
Stainless
Edmonton, AB
Is there anyone in western Canada that has the PartSource equivalent part number? Am I going to have to order this over the internet?
Stainless
Edmonton, AB
If anyone else is looking for the part locally Ford lists it at $79. It works out to about the same buying from Canada when you factor in our dollar and shipping. Who would have thought that from a dealership you could get shcu a good price? shrug
