pulled codes and miss fire
1993shoguy
maine
so i drove the car finally after motor swap and it is misfiring like no tomorrow. Checked the plugs and sensors and they are all good correct firing order pulled the codes and this is what i got.
327
115
715
832
715
715
832
Ive looked and cant find those codes any help would be great
shoff22
missouri
327 DPFE output circuit below minimum voltage
115 Engine coolant temperature (ECT) sensor out of self-test range
715
832
Those are all I could find on shotimes sorry if im not much help
1993shoguy
maine
i Just changed the plug wires and the dis mod and the coil pack and still a miss fire all grounds are correct. The car is a 93 atx with 215k on tranny and 110k on new fresh motor
1993shoguy
maine
i unpluged the mass air and it idled better. I also redid my intake and now the intake is no longer leaking. But still have misfire. Ive checked everything and i also changed the cam sensor that didnt help. I took it for a ride and i was having trouble with it trying to shift into second and third. Could the vss be bad and cause the misfire?
1993shoguy
maine
so i now have new codes
111 have that 3 times
115
715 two times
817 two times
632 two times
317 two times
315
754 two times
I really need help i have searched and tried everything
the 111 means that the koeo test returns no errors.
if you didn't reset the codes, you will keep getting all those old stored codes forever, so you need to reset.
the vss will not cause a misfire, but it will make you crazy by shifting randomly and stupidly, and can ruin the trans by doing so.
1993shoguy
maine
update reset the codes and will repeat the process again and i replaced the egr and no difference
