Puking coolant
HARLANGTO
Colorado
my 93 ATX is starting to puke coolant out of the reservior tank, it is not running hot but when I stop it boils out the top of the reservior. I refill the tank to the hot line and after driving it does it again.....
Are the fans meant to run after the car is turned off?
SHOhopefull
Boaz,Ala
Since I just had this happen to me...Radiator Cap is bad. Getcha a new one and your good to go :thumb:
Tecchie
Marysville, Washington
HA... Make sure you're running at least a 50/50 mix of coolant and water (not tap mind you)
I use at least a 70/30 mix of coolant/water cause I want my pump to last longer and have a better heat exchange/boiling point... :p
My $0.02
