Puddle of water on floor
1992SHOMTX
Vrrooommm...pssshhhh
Providence, RI
So I've got an issue that is not only annoying, but is going to rot out my floor in my SHO. Typically after a heavy rain overnight, I come out to find my passenger carpet soaked. I have a weathertech mat on the carpet and it typically has a little water in it when this happens.
I was thinking passenger door seal, because I think I've seen water there, but not sure.
It doesn't happen in carwashes, doesn't happen when I'm driving it, and just the carpet is wet. I'm so confused it's not funny.
Any help, suggestions, would be awesome. Everything but bringing it to the dealer. Leak wet downs aren't cheap.
Ben R
Minnesota
I had the same problem but, after my windshield got replaced it went away. Mine must have been a seal that goes around the windshield.
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
Check the firewall there is a A/C drain tube that could be plugged. I don't know exactly where but somewhere around center and could be a plain piece of rubber tubing that should drain to the ground. I am not saying 100 percent but sounds like a reasonable starting point.
sperold
Last to Know
Your sunroof drain line from the front passenger side of the catch pan may be leaking into the car instead of exiting on the outside.
most likely (in order of my experience) is sunroof drain plugged, windshield gasket, door gasket. A door gasket that will leak that much will almost always have extra wind noise, and a windshield gasket that leaks that much will usually have a wind noise, so have someone with good ears sit in the front passenger seat as you drive on the highway to see if they can hear any extra whistling type noises in that area.
1992SHOMTX
Providence, RI
It doesn't make any whistling noises, it's quiet as **** in the car. I'll check the sunroof drain. Where specifically does the drain route and drain onto the ground?
krewat
Long Island
This. Heater/AC box fills up, and flows over onto the passenger carpet.
My '97 Cougar does this - its AC drain looks like a "******" in the firewall. Gets plugged with crud from sitting outside. Run a twist-tie or some other piece of stiff thin wire into it, wiggle it around, it starts to drip.
Although the sunroof drain sounds reasonable as well. It's a plastic piece of tubing that runs from the sunroof area down inside the "A" pillar. If I remember correctly, my '96 T-bird "wet itself" a time or two until I realized the plastic tubing came off up at the sunroof. If it was ever installed correctly in the first place. Put it back on, problem solved.
Definitely report back :thumb:
This is a pic of the 2 drain hoses from the sunroof aka Roof Opening Panel
2010 Taurus Roof Opening Panel Drain Hose Routing
2010 Taurus Roof Opening Panel  Exploded View
Item Part Number Description
1 500A18 Roof opening panel glass
2 — Roof opening panel glass screw (4 required)
3 500A66 Roof opening panel shield
4 7854022 Roof opening panel trough
5 — Concertina blinds (2 required)
6 — Air deflector assembly screw (3 required)
7 500A26 Air deflector assembly
8 502B98 Roof opening panel frame
9 54502C53 Rear drain hose (2 required)
10 W702928 Roof opening panel frame bolt (12 required)
11 15790 Roof opening panel motor
12 — Roof opening panel motor screw (3 required)
13 54502C52 Front drain hose (2 required)
ToMang07
Maine
Long shot, but did you ever figure this out OP?
Sent from my SM-G960U using Tapatalk
shaker281
USA
I wonder if it would be a bad/good idea to use a can of compressed air to blow through the tube from the top at the sunroof opening? Or might this dislodge the hose and cause another problem?
Of course, if you have not been driving in the rain or the car sitting outside, it may be more likely to be the AC condensation drain line. Though same question applies re: compressed air.
And yeah, I know this is an old thread.
Juicybaka
Is there enough room to stick a ball inflater inside?
RAYJAY
WHO ME ?
UNION DALE PA
i just use the air compressor to blow out the line and run water to make sure there flowing pollen / road dust will block the lines,
Jamanson
Kansas City
Here are some photos of where the drain line is. It is behind the battery and brake fluid reservoir. I was able to bend a hanger to help me get it cleaned up and followed with air compressor. Cabin air filter was soaked and the fan was barely running. Nice and cool now.
Brumfield780
