Properly installing hubcentric rings
SeanMc
NoMoSHO
Coming home from work yesterday, I notice a noise coming from my driver side rear wheel. I figure it's the fact that I can't get the rotor on straight. When I installed it, everything seemed fine, and figured that when I put everything back together, the rotor and what not would straighten itself out. I was wrong. So, is there a trick to these rings? I hammered them in, and they seemed straight, but how do I guarantee that they are straight and that they are the farthest they can go?
SHO92
Upper Freehold, NJ
I'm confused... Your subject says rings, but in the post you talk about the rotor not sitting right.
The rigs should slip into the wheel or over the lib of the hub and be flat against the rotor.
K-Dawg
Treasure Coast, FL
Doesn't putting the 11.6 rotors in the rear require some kind of centering ring? I think that's what he's talking about.
SeanMc
NoMoSHO
Matt, I think you may be right. I noticed that the pads didn't have the springy thing on them. I guess I need to take them back to AutoZone.
