BlackonBlack89
Well last sunday we took the engine/tranny out of the opel. It was actually alot eaiser than I thought it was going to be. Almost 40 years old and only i bolt stipped!!! That made things easier had the engine out in 4 hours with a lunch break.
Couple pics from that
Well anywho I picked up an RWD SHO engine/tranny combo and today we separted it. And then did a VERY rough test fitment of the engine. It is super tight and never got it fully down where I wanted. The cross member and the oil pan is a known problem hence the dry sump thread. Still looking into that myself. But the width of the engine is close but will make it. Height is still a problem though.
Here some pics of the day.
First getting it in. moving some stuff out of the way.
Actually the engine has to sit alot closer to the firewall. The old heater box is going out and then the trans tunnel has to be modifed along with tons of other stuff.
custom hugger headers needed
reason why a custom oil pan is needed or dry sump setup.
Thats all. Hopefully it will fit. I don't know though. Alot of work will be needed. Right now I am being optimistic but its hard when it's so close.
So why not go with a steel pan? It'd weigh maybe 5lbs more than the aluminum one, and as long as he ran an external oil cooler, heat transfer should be fine.
