problems with rear tensioner pulley?
Revere sho
Revere MA.
just wanted to ask im pretty sure i already know the answer but the tensioner pulley for the power steering pump and the water pump has bearings inside of it right? reason why i was asking cause i took it off of the tensioner to inspect it and it just fell apart. i seen grooves in the sleave that looked like it was for bearings but there were no bearings to be found.
Ishodu
Yeah there are supposed to be bearings in there. Sounds like you have a massive failure of them. Josh T can help you out with a replacement bearing.
Rob94
Northbridge MA
I have a spare pulley. Not sure if it's the one you need though. I'll check it out. In the meantime, send me a PM to let me know if you're interested if it's the right one.
thatSHOguy101
