problem reinstalling manifold
warmonger
earth
so i new that the removal and install was too easy,and was waiting for something to go wrong...and it did...i need to know if the runners are specific to either the front tank or rear tank? i have the manifold back together,and upon instaling it it wont sit flat,i've found that the little studs in the heads wont line up with the holes for them in the runner ******?!?!?!?!! so again,is there a certain set of runners that go with the front tank or vis versa? otherwise,is there a trick to get them to line up?
40BelowSummer
Puerto Rico
The runners are not specific, they are the same so don't worry about mixing them up. Assemble the manifold and tighten all the 12mm nuts on the intake. It should bolt right up.
Try loosening all the hose clamps on the runners-to-butterflies, installing the intake and then tighten the hose clamps after it bolts up. It may take some massaging but it should bolt right up. Watch your secondary vacuum lines too.
warmonger
earth
thanks,luckily she's off the road in the winter...i've tried everything to get it back on..the runners seem to close together,for instance i had to force them to clear the fuel rail?
40BelowSummer
Puerto Rico
Did you try loosening all the hose clamps?
Seems like each time I put a new intake together, it took some massaging to get seated. I have had to gently force them past the fuel rail too. Keep trying, you'll get it. Make sure you aren't smashing any vacuum lines and make sure the gaskets stay seated. :thumb:
SinisterSHO
Rust free
630, IL
I agree on loosening the hose clamps. Mine was fun to try and install and not scratch the polished runners.
warmonger
earth
yeah..i spent all day gasket matching knife edging,porting,cleaning the manifold and head...also painted the manifold and runners...of course i scratched the **** out of it after i started kicking it!!! i tried to loosen them,but nothing moves when i try to pull or push on the runners...i'll try again tomorrow..do you guys know of anything else i should do while the manifold is off?
john buck
SHObuck
Cookeville, Tennessee
well i fu wouldnt have already painted it i would recommend having it cleaned by a machine shop.. they do some kind of acid bath or something to remove all the residue:thumb:
40BelowSummer
Puerto Rico
I would paint the timing cover and valve covers if you feel like it, it makes it look much better.
Throttle body coolant bypass?
HotRodKid
mmmmm ... turbo
Western NY
we had the same problem when putting the powder coated intake on somedudes turbo sho
luckily, we had a spare motor sitting in the garge, so we were able to slap the inatke on THAT motor, and get a VERY good visual on what the problem was
the final decision was just basicly its a complex intake, and a fraction here and a fraction there of misalignment adds up
we loosened all the clamps and bolts, removed the cross over tube from the passanger side, squeezed the surge tanks TOWARDS each other, and dropped a load of bolts in
it took some work, but as soon as you get the bolts started, the manifold will wind up bolting down level and leak free ... just dont screw up the gaskets on top of the runners in the process
install the cross-over last ... that seamed to be what realy aggravated the problem on alex's car
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I know mine dosent quite fit, and I was thinking of wrapping mine in a towel, loosening all the clamps, and pulling it together with some tow straps. It might be off 1/4" but I knew it would be a little off when the surge tank didn't quite fit. :) Oh well.. I'm just wondering how all this freakin enamel is going to smell :) And for how long, considering that I've painted.. ummm oh yea everything. :)
twr
whoohoo
half-way there, I think.
If you are using the stock couplers on the runners, they are direction specific. There is a ridge in the inside and it is not in the middle, but offset little. The deeper side fit over the butterflies, the shallower on the runner side. I found this out the same way you did, put it together and tried to bolt it on and it didn't fit.
warmonger
earth
ahh...that explains why no matter how hard i try to push the tanks the runners wont move
somedude_001
Western NY
i didn't know that. I used a ratchet strap to pull the tanks togeather, i didn't have to pull it much but it was a pitta. I thought it warped in powdercoat.
warmonger
earth
he was right,i pulled it back apart,and changed the couplers around(also got rid of the **** in the middle)...but i have a new problem***see thread in emerg. tech section***
AREA 91
PA SHO SHOP
Area 91
If your intake has been powder coated, you must check all the mounting flanges carefull for excess coating. M<y perticular problem was that some of the powder coating got into the small holes on the underside of the runners. These holes line up with the studs/dowels that are on the heads themselves. Also make sure that where the cross over tube bolts down, that there is no powder coating on the mounting areas. This will effect the grounding of the DIS.
1993MTXSHO
Its a Taurus...
Jersey
crap...
AREA 91
PA SHO SHOP
Area 91
Good call on the stock couplers. I never even considered that, due to the silicone's on my +.:thumb:
