F-22 Raptor SHO
Ok guys, this one has me stumped. I provide every detail I can think of, so it is a bit long.
95 ATX. 86,000 miles. All up to date on Maintenance. Ted LPM. Car kicks butt as it always has.
Last year (October) I moved from Michigan to AZ. Car was in airport parking lot in the AZ valley for 1 weeks (read: 100 deg heat). Upon returning from the airport with a full trunk and family in tow 40 miles into the 120 mile trip up the mountain, the car quit: stumbling, dying, choking, pulled off the side of the road.
IRCM was making a clicking noise with ignition on, it would crank, but wouldn’t stay running (more choking and dying). Code read was 511 (No power to PCM pin 1 or bad PCM processor. No other codes. Now typically this would be a code all the experts would say "hey its the lpm". I got it towed and of course the car ran fine when we reached our destination 100 miles away which by this time, it was a cool evening and the car cooled down.
I still suspected the PCM might be bad (or that pin 1 was having problems). I disconnected the harness and examined and reattached it, checked the LPM connection that seemed fine. Problem resurfaced a few days later during city driving (modest temperature. I wiggled the PCM while in the left turn lane and it came back to life. So later I secured the PCM and all was well.
Fast forward to last Friday: Returning from airport with family and full luggage, full cabin, it quit in the same way (in rush hour of course). Temp was not outlandish: running on M with new rad and dex cool. Only code was the 511. No IRCM box clicking. Wiggle PCM trick didnt work, disconnect and reconnect harness didnt work. Off Road SHO came with another computer (93 ATX X2J). We swapped it in. Car ran perfect. Ran codes to be sure, all was ok. Ok, bad computer. Figure I own Tom a computer and a steak dinner. Came home up the mountain (evening 60 deg by now). Car ran fine.
Ok, yesterday was returning from Sedona, (25 miles up a switchback mountain road (3000 foot altitude change), car quit again with the same stumbling and dying (still had Tom’s X2J computer with no LPM) If I waited, the car would start again, but die within 1/4 mile. No CE light, thrown but there were 4 codes pulled, but I was having problems running the KOER test correctly which later I thought I was able to remedy by Goosing the gas after o/d button was turned on and off. Codes were:
129 - No MAP or Mass Air Flow sensor change during "goose" test
167 - 167 No Throttle Position sensor change in "goose" test (must get at least 25% rotation)
225 - Knock sensor not tested (ignore if not pinging)
632 - Transmission Control Switch (TCS) (OD button) should be cycled once between engine ID and Goose test.
Nursed car home to garage and let it cool down.
Votage to TPS and MAF was fine.
For grins I yanked off the maf and tps then started the car, I was able to reproduce the problem only one brief time out of 5 attempts but it gave me a CE light immediately. I did observe that the MAF plug wasn’t as secure at it could have been, (clip wasn’t all the way clipped, but recall, at the airport I got no TPS or MAF code). Car ran fine.
I did think the heat on the DIS could have been a potential cause as 1: the dis was a swap out when I thought it was going bad 2 years ago, I never put the original back on, and 2 I never did use heat sink compound, rather I used dielectric grease. I put my original DIS back in last night, used liberal amounts of radio shack heat sink compound and put it all back together. Reset computer and idle.
Only facts that seem to be constant are:
Happens when car is under moutainous driving on hot days
511 code is thrown
Problem is sudden with no warning.
PCM wiggle seemed to help once, but not any more.
Chip is not on second computer, so I dont think that was the problem.
There is only one way to see if I get the problem again and that is to put my family in danger by driving up the mountains with a full load.
Any suggestions?
I am going to recheck ground wires today, and check the power supply to the PCM.
511 code is thrown
Any suggestions?
