Well I just got a PRO M 80mm MAF for my SHO and it definitely did help the performance QUITE a bit. BUT, now the check engine light keeps coming on so I checked the codes and got the following:
157 MAF Circuit below minimum voltage;
211 PIP Circuit Fault;
542 Fuel Pump secondary circuit failure.
Obviously the 157 is whats causing the check engine light to go on cause the other 2 arent codes that would do that. BUT, what does it mean? Does it mean that I need to send the MAF back to be fixed? I also have no idea what the 211 and 542 mean exactly. Can anyone help?
