PP vs non-PP SHO Transmission
ThatSlowSHO
Indianapolis
Unfortunately it’s looking like I’m going to have to replace my transmission in my 4th gen after already replacing the PTU. but does anybody know if I can put the 3.16 perf transmission in a sho that had the 2.77 non-perf transmission? Would it affect the tuning at all? are all the mounting faces, gaskets, etc. the same? I would assume they are but was hoping someone could verify for certain.
Ta2dResqr
Central Ohio
I am going to assume that it would affect programming. Different computers will be looking for that gear ration for many different things (speed, slip, etc.). Is there a reason? I am going to also guess that the main body will be the same dimensions but there will be fitting differences (such as for coolers). The main transmission cooler is a y hose at the radiator so you may get away with everything being the same. If you really wanted it for some reason, everything else should be programmable with ForScan.
BradM
That's a good question. I don't know for sure but I believe the PTU and rear diff set the final drive ratio, which is the difference between PP and non-PP. The trans should be the same (compare trans codes on the door tag). Someone here will know.
ThatSlowSHO
Indianapolis
this was also something i wondered, but i couldn’t word it in a way that made sense. thanks!
