power steering pump removal, 93 ATX
Broadkil
ohio, toledo
ok the pump has been bad in this car for like a month and the pulley went dead on me as well (big shock i know) BUT i cant seem to figure out how to get the old pump out of the car...i have the new pump
and on the old pump i got three of the 4 bolts out of it
BUT i cant seem to reach the one to the back of the pump
HEEEEELLLLPPPP!!!!!!!!!!!!!
i gotta move out of the place i am at in a week so i gotta get this done ASAP!
any help will be appreciated
thanks
Mike93
Go Sabres!!!
Buffalo, NY
You may have to remove the y-pipe to get at the rear bolt on the pump, access it from laying underneath...I just did this to my '93 which was an atx, now mtx, and with the pipe off it's very easy to access. I can't remember how much the atx trans interferes though...
TYSHO
Earth
I used a 1/4" rachet and whatever size socket it was and reaced behind the manifold. There were some parts that needed to be moved to the side I believe, but it wasn't that hard once I got in the correct position.
Broadkil
ohio, toledo
what kind of parts did you have to push aside?
and i forgot to mention the pressure line is still on :p
and thanks man!!!!
TYSHO
Earth
From what I remember, I removed the main vacuum hose on the back of the manifold, the rear manifold bracket so I could remove the wiring brace deal and move the wires aside, and the ECC and ABS connectors with the black plastic cover on the firewall. I think that's all of it and it allowed me to get in there without hand/wrist cramps.
For the line going to the pump.....oh man! :oogle: I tried to get that thing off with the correct size wrench and it wouldn't budge. I even used a pipe over the wrench for extra leverage and it wouldn't do anything but begin to strip. Since I was pulling it from a parts car, I chopped the metal hose and took the rest off with a deep socket and impact.
SeanMc
NoMoSHO
The ATX pump is far easier to remove than the MTX due to the engine being farther forward. GoofSHO swapped mine out in about an hour.
Broadkil
ohio, toledo
SeanMc....how did he do that?
and also (this is for anyone looking at this thread)
is there anything i should know before i remove the cam posstionning sensor?
its kinda in my way and i want to remove it to make it easier to get at the last bolt on the car,,,but i cant find any info about this nor any precautions i should take
SHOtimer
#2910
Santa Clarita, Ca
Just unplug it and remove the two 5.5mm bolts and it will come off. Repeat to install. It is nonadjustable, so you won't screw anything up.
Doug
Redskull
Badass Mo'fo
New Haven, CT
I just did this on my MTX a few weeks ago...what a pain in the @$$....you gotta take the wheel off, the splash shield out, AND the rear motor mount...I fumbled around for a day trying to avoid taking the motor mount out, but I couldn't find a way around it.
BTW, I found the long hose from the resivoir to the cooler all sort of brittle and torn from being routed past the exhaust manifold; it's a good time to check it while you're under.
alan
Broadkil
ohio, toledo
yeah i know what ya mean redskull....my stepdad got my old 91+ and i looked at the ford manual for this and what a pain...i thought i was gonna have to do the same till i looked a little closer at the car
so what year is your MTX red?
SeanMc
NoMoSHO
I just watched and it seemed like almost instantly it was done.
gurucomputers
Everett, WA
thanks
Its very easy to do, just a little tight. Jack the car up on jack stands and remove the paa side tire. from there you can get to the steel line that screws into the side facing the firewall. There is a bolt on the back that you will need to remove from the back while your there. After you have that removed pop the hood and remove the remote fluid resivor. You will need a catch pan. Loosen the P/S pully nut. Remove the belt and pully. No need for a pully puller as will will come right off after you remove the nut. There is 3 bolts on the front side, remove them and it is out. I just did it about 3 weeks ago and took about 2 hours with a few cursing breaks in there as well.
Good Luck.
Redskull
Badass Mo'fo
New Haven, CT
I don't know if it's the same, easier, or harder, but heres what i did for my 94 MTX:
1. take out battery, loosen resivoir and reposition it, remove engine damper
2. remove wheel/shield
3. loosen pully nut, loosen tensioner, remove belt, remove pully
4. remove big-@$$ nut holding the motor mount (22mm?)
5. Jack up the engine (with a board under the oil pan) about an inch higher than normal
6. remove the bolts holding the motor mount to the block (you may need to adjust the hieght of the engine to release some of the pull)
7. jack up the engine till you can get the mount out
8. take out the rear bolts on the pump, and the three front ones, wiggle the pump out through the bottom
Again, ATX's are supposed to be easier, but who knows
alan
Dr.Evil
No Dif Pin!
Sparks, Nevada
Sorry to make you go through all of that and have it not work. It was cool chatting w/ you guys though.
If I can get the pump off in a motel parking lot with minimal tools, 1600 miles from home, and without removing the motor mount, then it you should be able to get it out no problem. (pully splines stripped and shreaded the belt on my way back from the convention)
GoofSHO
HUGE Dreamer
Vegas
I can't remember everything I did....I just "do it"....
B
TYSHO
Earth
It's no problem! If anything, I learned to start with the metal line first and if it doesn't come off, then I wont mess with anything else. :) My next job is the power steering rack on the 92. :doh:
