power mirrors
rollie
new york
Hey can someone help me, I have a 1994 atx and the thing thats I'm trouble by is that the power mirrors do not work. I've checked the connections and the fuses, I've even attached another mirror. still no movement, could there be a relay that I have n't come accoss yet.
Rollie. :confused:
rollie
new york
Rollie. :confused:
contact me at [email protected] with an answer.
rangerj
Brunswick, Ohio
Do a continuity check of the mirror's circuits, assuming the fuse is not blown.
Then check for power at the mirrors switch (battery voltage).
If the circuits are OK, and there is power to the switch, then the switch is faulty. The most common cause of BOTH mirrors not working is a faulty switch.
Before replacing the switch I usually apply battery voltage to the mirror motor wires to test the motors (at the switch) to make sure that the problem is not the motors. The chances of all four motors being bad is slim.
Your most likely problem is a failed switch, but do the diagnostics.
rangerj
