Power loss
jenningsj
california
Ok ive looked through old posts for 2 days now and none of them duplicate exactly what i have. at wot no power other than that it runs great, great idle, starts fine hot and cold, 1/4, 1/2, 3/4 throttle fine, runners open fine no engine light either.....is it a cat, maf sensor, would appreciate any feedback. :munch:
Ishodu
Sounds like it could be a MAF issue. Can you check your codes? Take a look in the How do I section for instructions on how to get the codes for free and quite easy to do.
tps or mafs are likely candidates, but check codes to see if there are any to help you narrow it down.
Vnuk1
Mr. Mayhem
Minnesota
MAF unplug it and drive it with it unplugged, I'll pretty sure that's your problem cause I had this exact thing happen to me. Starts fine and drives fine but when you go WFO it falls flat on it's face..
jenningsj
california
you guys were dead on, thanks, that and there were 2 upper intake leaks and egr valve was bad when i smoke tested it:woo-hoo:
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
This is my same issue. If I unplug the suspect MAF, will the problem go away?
