Ok, back again with this problem. During these repairs I also repaired the secondary air pump causing P1413 code. Moreover, I replaced the gas tank to eliminate the P0453 code because the pressure sensor was missing on it. I have no more code on the car.
Tryed the car, nothing changed. The bug commonly coming at 4000 rpm depending on the ambiant temp. Sometime, the torque converter just seems to disengage (no power at all) and sometime it seems to be lock one second the other not, when it's occurs I just have to retreive gas on the pedal and the t/c return to his place correctly. But it doesn't seems to me to be a trans prob, it will shift perfectly in all gears at low/medium rpms and in cold conditions. It's driveable but it doesn't offert performance like a sport car.
I tought a lot about that recently and I remembered that this bug came after I replaced all rear coils and cleaned my intake... The car shift perfectly in all conditions and rpms range before this maintenance.
4 things coming on my mind :
1) When I replaced the coils (for news ones), I also replaced the plugs and for one, I heard a little "tick" when I bolted one to the motor. After some time, I'm begining to had a misfire. I checked my rear bank and I found that the "tick" plug craked badly on the white ceramic part. I changed the plug but not the
coil... Does the coil going bad because of this ? I must say that I have no misfire at low or high rpms...
2) During this operation, I had to seperate the
rear wiring from the head with a screwdriver because it was frying on it... I put some plastic protection between head and wiring but not between each wires. Maybe some wires lost their protection and causing electricals probs or noise to PCM ?
http://www.shoforum.com/index.php?threads/cop-harness.107677/#post-1154424
3) When I cleaned my intake, I found my 2 gaskets between runners and lower intake were a little rusty and I put red silicone on them just to be sure to doesn't have a leak there. Maybe I have a leak there because I put too much silicone... What are the effects of a
leakage on the intake (motor sucking air somewhere) on motor performances ?
4) At the same period, I also changed the gas tank. We replaced the old
gas pump (136 000 miles) in the new tank which is difficult to put in the tank mostly because of the gauge and the filter. Maybe the pump is going away but I rarely rode something about a bad pump and when they go bad, they just stop working... (Edit : the car always starts at the first try, no pressure lost on the line.)
I will be very gratefull to have yours advices and past experience on that kind of probs. I'm begining to be very tired of this, I have this car for 2 years now and it's worked correctly only a few months...
Thanks guys,
