Power Antenna Module
JATRAMMELL
93 Red ATX
CLEMMONS NC
Having trouble with my radio and power antenna on a 93. Think it is the "power antenna module"
Is the black box labeled P25 the power antenna module? If not, where is it located and what is the part number?
This picture is behind and to the upper right of the glove box.
SHOMA
Springfield, MA
I was having a hard time with my antenna. Replaced it with a known good one, no luck.. ended up it was that relay box, from what I can see that IS the one I replaced.. Good Luck! Whats the problem you're having?
JATRAMMELL
93 Red ATX
CLEMMONS NC
Gremlins! Antenna goes up and down on its own with radio on or off. Radio was working but now it isn't and CD player isn't working either. Power is good to everything. CD player plays but no sound. I'm going to replace the radio and see if that helps. If not, I will see if I can find a module.
Thanks for the reply. I was beginning to think I was looking for something that didn't exist.
JATRAMMELL
93 Red ATX
CLEMMONS NC
Got it fixed. Just a bad radio. Terry--nc89sho--had an extra from his 93 and everything works perfectly now.
