WakaShoMan
If anyone here is familiar with the Police or 4-bolt SFB's, I need a bit of info.
When I match up my police bushings with the Recall kit, it seems like the Recall washer will not fit. There is a prodtruding "shoulder" at the hole that does not fit into the Police bushing hole. I did a Forum search, and someone said that when using Police bushings you do not use a washer, as the Bushing does not need one. Is this true?
Somebody also asks the question as to whether or not you can simply saw off the 4 bolts on the police shims (for rear SFB installation) insteda of drilling locating holes in the subframe. Can they be sawed off (rears) and is there any ill effect?
Any other pieces of wisdom that y'all could share to somebody trying to put Police style bushings in a stock '89 rear SFB location?
Thanx in advance....
