Please verify Spindle/Hub interchange.
93rev2sev
Hockeytown
Spindles and hubs from a 93 SLO fit on a 93 SHO?
The junk yard is telling me the splines in the hub are different. They also show a different part number for the spindles themselves.
93rev2sev
Hockeytown
Thanks
The JY has a set of 93 SLO spindles for $70 but he said they wont work...different splines....
Then, he told me that he has a 95 ATX SHO...he's gonna sell me the whole deal for $95...hubs/spindles/calipers/rotors.
So...I'll finally get the upgraded brake setup.
Is there anything else I need to pick up to complete the conversion?
K-Dawg
Treasure Coast, FL
If it were me, I would only get the knuckles from the junkyard. Then get new hubs/bearings pressed in, new/reman calipers, and new rotors.
93rev2sev
Hockeytown
The ones that were pulled were 95 NON ABS spindles. I pointed that out to the guy and he said "oh sh!&".
I got the spindles, calipers, rotors, and all the hardware for $85. And he's sandblasting the spindles for me.
I'm just going to run without ABS. Screw it.
hawkeye18
Sorta cares
Norfolk, VA
yeah, who needs ABS anyway? Now, all you need for the 96+ brakes are caliper brackets from a 96+. And, obviously, the rotors. and pads. the 598 pads go with 96+ brakes, 602 pads go with 95-. I hope this makes sense!
93rev2sev
Hockeytown
Yes, it does....
for now, I'll be happy with the 95 pads/rotors.
What are the different rotor sizes???
pre94=10.6" ??
94/95=11" ??
96+= ???(more than one size?)
93rev2sev
Hockeytown
When working on the upgraded brakes, don't forget to loc-tite the slider pin bolts or they might back out and send the caliper bracket and pads into your wheel...:zoinks:
Don't ask...
