please help!
bmray21
Ft. Wayne, IN
went out to start my '92 and nothing happened. tach didnt move, yet i could hear the fuel pump. this leads me to believe it is the cps and water pump. so i decided to run KOEO test even though the engine wasnt warmed up. i did the test twice and will be doing it again just be sure but the codes i retrieved were 114-act out self test range, 116-??, 542-fuel pump secondary cir. failure, & 556- fuel pump primary cir. failure. im not sure were to go next so any help would be greatly apppreciated!
thanx for your help
bryan
gregr
Orange County, NY - USA
Same thing happened to me this week, I had worked on the intake and forgot to tighten the crossover tube bolts which grounds the DIS system. Check these 2 bolts, as well as the ground strap on the back intake bracket. My car runs fine now!
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
SHOShop LPM
SHOShop UDP's (coming soon!)
IPT triple gauge pod with Autometer - Volts, Oil Pressure, and Water Temperature Gauges
SHO2NV
Not low anymore
Angola, Indiana
Hey Bryan, if you can't figure it out on your own lemme know and I can see if Chuck(toolboy79) would be willing to swing by your place. He's a tech at Dimension Ford West and one of my SHO buds. That or you could call there yourself and ask for Chuck Curtis. Good luck.
John
Green 94 ATX
SHO2NV
[This message has been edited by SHO2NV (edited 01-11-2002).]
bmray21
Ft. Wayne, IN
hey, i emailed you, im thinking my problem is my starter. i tapped it while i was underneath the car and it started. i called autozone and advanced auto. both places sell them for $96.99. what do you think? most likely the starter? thanx
bryan
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Did you 2 guys from Indiana know about the TRI-State SHO/SVT club? Based in Lima Oh, members from NW Indiana, Northern Ohio, SE Mich.
Perry Toledo,Ohio
