please help
jimbobzsho
westland mi usa
just got my intake back together from cleaning it and new gasket set and i cant get it to fit back on the motor did i possibly reassemble it wrong? it's too tight around the fuel rail
Bizzy
I think that it will only go back together the same way it came apart...although I could be wrong. Keep trying, there's bound to be something simple keeping it from fitting right. If you need a working model let me know and I can drop by tomorrow to help you out.
Proud to be an American!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
You will need to loosen all of the hose clamps on the manifold. Only retighten them once you have the runners torqued down to the heads.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
jimbobzsho
westland mi usa
i got it on all good now thanks for the help.......but new prob. my throttle response is bad real slow. what do you think
S
slosho
Guest
Vacuum leak??
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" line
Lighting mods
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
jimbobzsho
westland mi usa
i just went through the hole vacuum system and i cant find a leak and sprayed starting fluid around the engine compartment and no change in idle. would the o2 sensor's sho a engine light?
9
94ShoATX
Guest
Yes, The 02 Senosors shows the check engine light.Mine did not come on untill after I drove for a few minutes though.
