planning some work need a check on my plans
fred79
pittsburgh
1995 sho blown tranny:
plans are to have the shop pull my old tranny, and and clutch and flywheel and replace the rear mail seal. I want them to change the rod bearings, and then reasemble with the tranmission I rebuilt and a new tranny mount and pinch bolts, and aluminum subframe bushings and new bolts.
can anyone think of anything else I should have them do while the subframe and oil pan are down, I have a minimum of cash so I can't afford to do springs or struts, or any thing rediculusly expensive.
thanks, any ideas are appreciated
Mr Anonymous
Tire Wall
I can understand having the shop that is doing the tranny R&R replace the rear main seal and carrier gasket, but honestly if you could rebuild a tranny yourself, you could certainly do the rod bearings on your own, and probably at a fraction of the cost.
Since they will have the subframe and y-pipe out, you should have no problem dropping the y-pipe to pull the pan and do the bearings. Should cost you less than $100 to do yourself.
You don't mention having the flywheel machined or replacing the clutch. Are you at least having the flywheel done? If you're re-using your old clutch, you should at least replace the TOB and quill sleeve.
fred79
pittsburgh
sorry yea the quill sleeve and TOB are being changed. and about 3,000 miles before I shot the diff pin throught the tranny case I had a new clutch put in I didn't have the flywheel cut at that time since it was in good shape and since I have worn the clutch in on that wheel I figure it wouldn't be prudent to cut it now.
I am sure I could do it all but it took me almost a year to get the time to do the tranny and find all the peices and I am tired and ready to have the car back so its worth paying some one else to do it. I also have a decent mechanic who is fair about the hours he puts in to the cars. I figure it should cost me around $500 for just the labour, and I need probably another $120 in parts I have bought already.
had an Idea should I have them change the ball joints while they are there or only if they are bad?
