SASHO91
Zoom Zoom
not my car.....
but a 93 ATX....
Friend had it die on him, and was not able to restart...
Well today, Me and another friend, went over to go check it out.
We swaped over a few parts,ECT, IAB, DIS, and checked the CID.
Still nothing, Though the ECT helped alittle.
We keep on trying to start it... nothing... its cranking, and turning over, but doesnt want to completly turn over... and it also would through a backfire out of the intake....
Now, i knew it had to be an ignition related item... DIS, COIL, CPS, CID, or something.....
well after some food, we go back out and try to start it again... this time, it is alittle better, and actually starts turning over... during the whole process, i was going back and fourth with WOT starts and regular starts...
so i went WOT, and it started.... i had to keep it up at 2k, but as soon as i let the revs drop, it started to ping BAD.... and it wouldnt keep idle... seemed like a miss....
So, from what i can gather, is either the CPS, took a complete dump... More than likely.... or it jumped timing... which, would cause the pinign.... im guessing on that part, as i have yet to hear a motor ping like that....
And i dought that a CPS could cause that ping, but like i said, i have not ever experinced this yet....
so.. what do yall think... we are heading back over tomorrow, with a Coil pack, and plan on taking a look at the CPS... the coil pack, is just "in case" for reassurance.... it might be the coil pack, but, with the ping, i just dont know...
isnt pining from to much timing.... if so, could the CPS, and the coil pack be causing this....
Thanks for the help....
but a 93 ATX....
