multishowner
Going to try this again...
Good day all,
I have noticed that the site isn't as active as it once was. I guess everyone is out driving their SHO's instead of typing about them, or everyone is fed up this forum kicks you out before you have a chance to post something (hence the second time doing this).
Here is the beast released from it's cage. Now what do I do with it?
I pulled this to replace the TC seal and possibly upgrade the TC. My SHO was losing the (very expensive) trans fluid on long trips. I think I have found the cause, but I don't think I will try to prove this since it is time consuming and expensive to replace the fluid. I found an area under the ABS system the is crimping the top line from the trans. I SUSPECT (guessing here) that the crimp is causing a back-up of fluid, when the RPM is kept constant for an extended amount of time, and the fluid is finding it's way out the vent. OR the other option is that the slow down of fluid through the cooler is heating up the fluid too much at constant RPM for extended amount of time.
The cage from which it came... The A/C compressor was the most difficult part to overcome. I had to lower the engine without pulling the compress with it.
Here she sits, patiently waiting the good stuff. Gotta keep the neighborhood looking presentable!!
CAN SOMEONE PLEASE TELL ME WHAT THIS IS FOR?? Will a stright pipe work in this location? Do they make them with the flanges?
Well, I hope you all like my project thus far as much as I do, if not just give yous something to read.
Cheers!!
Good day all,
Cheers!!
