Picky Door Chime
SHOOFF508
Out of Retirement (again)
Westport MA
My door chime works all the time when you leave the headlights on, as it should as an alarm.
It however does not sound when starting the car as a seatbelt chime.
It also does not work when you have the drivers door open, key in ign.
Sometimes it randomly works with the drivers door open, key out of ign.
I checked the connection to the chime module and all the wiring looks good. I also checked the pin switch in the drivers door and confirmed correct dome light operation so im pretty sure its not a door switch.
What do you think is going on here guys ? This isnt a big deal just something odd i noticed.
1993MTXSHO
Its a Taurus...
Jersey
dunno if its a sho thing or not but mine does the same thing, i figured its broken w/e im not messing with it lol. However, I think mine is because of my ignition because if i move my ignition a little bit it will start working, then move it another way sometimes its stops.
SHOOFF508
Westport MA
yeah i played around with the tilt wheel and it seems its in the column and not worth fixing. i know the car was stolen at one point and had the ignition cyl. replaced.
jesshasasho
SHOgirl
Canton, Ohio
Mine does the same thing when you move the ignition back and forth. Must be a SHO thing. I thought the car was stolen too because the ignition is so loose and you can almost turn it to aux without the key, but I have seen on here that lots of others have the same problem.
SuperHO
Mental Patient
St. Joe, MI
thus the reason I just disconnected the damn thing and let the autolamps do their thing
