Pennzoil Syncromesh
MelectroK
Michigan
I have heard that Pennzoil makes the GM Syncromesh and is the exact same blend.
I also found this. http://www.pennzoil.com/products/gear_oil/syncro_fluid.html
Can any prove, confurm or deny that this is true or not.
Also in eather case, do you guys mix the syncromesh with other fluids or use it strait.
Im thinking of doing this, but I have no problem shifting right now. But I have 170000 and dont think it has been changed in 100000 miles.
warmonger
earth
yup,its true. penzoil/synchomesh straight up,no chaser :cool:
were are you guys finding it though? i cant find anyone that carries or can order the penzoil stuff.
projectSHO89
SHOless In St L
I've seen it in local AutoZones. haven't looked for a couple of years, not sure if they still have it or can get it. Call your local store and ask.
Steve
jayro
Auburn, In
It's avialible at Autozone. It is stocked with the differential gear oil, not the regular ATF. The bottle looks like a diff. gear bottle as well.
I was wondering if anyone had been able to compare this to Mobil 1 Synthetic? I am getting ready to tear into my MTX and was wondering if it would be worth switching. I am currently using Mobil 1....from what I have read, different trans react diffently.
Jeremy
wood_e
The dude
Ames, IA
The SHO specs ATF. Synchromesh is somewhere between ATF and 75w90 gear oil. It's on the thinner side of those 2 extremes.
That having ben said, in a few days I'm putting GM synchromesh in my Audi that specs 75w90 GL4. VW guys like the stuff and it will smooth that 1-2 shift thats difficult when cold.
MelectroK
Michigan
Is everyone at least in agreence that the Pennzoil and GM Syncromesh are the exact same thing?
wood_e
The dude
Ames, IA
Not sure - I've heard yes, but I also have heard that the GM blend is different.
projectSHO89
SHOless In St L
You can bet that the usage of the name is done under license.
There's no way in heck that the owner of that trademark is going to let products of different specifications to be sold under the same name.
Steve
VADERSHO
C-DAWG
Tulsa,Oklahoma
They are the same thing and it will save you about 3bucks if you buy the Pennzoil Syncromesh at AutoZone I just put it in my 95 MTX that was getting hard to shift and it has made a good difference
MelectroK
Michigan
I guess it really dont matter, I found the Pennzoil but it still 7.99. Isnt that what you find at GM?
