My 93 MTX w 176K has been making an intermittent noise when coasting or in reverse. The sounds varies a bit from a crackling to a faint clunking. It seems to be coming from the passenger side front area.
I have recently replaced virtually the entire suspension, tokicos/eibachs, control arms, tie rod ends, end links, sway bar bushings, strut rod bushings (TPR) etc. I also added aluminum subframe bushings.
The carrier bearing on the intermediate shaft has an oil film all around it but doesn't show any signs of being loose, all the rubber is still in good condition.
I wiggled the intermediate shaft and there really isn't any play in it, the half shaft connecting to it has about 1/8" of play which I'm assuming is fine.
Reverse seems to be where it is most noticeable. It almost seems sluggish as if something is binding somewhere. 1st thru 5th are fine, except for the occasional noise while coasting.
I've had this car 13yrs and it never used to make this noise.
Any ideas?
Thanks
Any ideas?
Thanks
