Part #'s
bigsho
sterling va usa
I went to ford to get prices on parts for the 60K. They said they didn't have plug well seals. Does anyone know the part # for them. Also is this the part # for MTX wires E6PZ12259B. Thanks
Robbie
95 MTX red
SS SNORKEL
26 sway bar on
24 sway bar on floor
SHO NUT motor mounts on floor
IPT 3 gauge pod in box on floor
Rob94
Northbridge MA
Don't go with Ford.....go with our sponsor, SHONut Performance.....much better prices and fast service.
Rob
White 94MTX
K&N Filter otherwise stock
bigsho
sterling va usa
Its only going to cost me about $350 for all the parts.
Robbie
95 MTX red
SS SNORKEL
26 sway bar on
Here is a list of the best parts and sources I have found. If anyone has located a cheaper source for these parts, please let me know.
Top End Engine Work
1. Valve gap check/adjustment, SHO NUT Performance, $3.48/shim
2. Spark plugs, Motorcraft AGSP-32PP, FordPartsNetwork.com, $3.99 ea. or Discount Auto Parts, $3.49 ea.
3. Spark plug wires, 3.0L: Motorcraft WR-4033, FordPartsNetwork.com, $83.99+s&h, 3.2L: Motorcraft, WRE-4081, FordPartsNetwork.com, $134.99+s&h
4. Valve cover & plug well seals, Fel-Pro VS50378R, O’Reilly, $91.99+tax or AutoZone, $72+tax
5. Intake manifold gasket set, Fel-Pro MS94831, RockAuto.com, $46+s&h
Front End Engine Work
1. Timing belt, Gates T248, RockAuto.com, $32.82+s&h
2. Accessory belt(s), 3.0L: Gates K040500 & K060445, RockAuto.com, $10.48 & $11.41+s&h,
3.2L: Gates K060854, RockAuto.com, $20.58+s&h
3. Water Pump, 3.0L: A1 Cardone 57-1373, O’Reilly (or NAPA), $61.45+tax, 3.2L: A1 Cardone 57-1458, O’Reilly (or NAPA), $67.99+tax
4. Crankshaft Position Sensor, Wells SU242, AutoZone, $42.99+tax or Borg-Warner CSS54, O’Reilly, $56.29+tax
5. Front main oil seal, National 710220, O’Reilly, $7.99+tax
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
fredhurderjr
www.neshospecialists.com
FYI, I got Kelly/Springfield comparable belts to the Gates K040500 & K060445 for $21 including tax walking in to AutoZone in RI last week. RI has 7% tax.
For the intake gaskets, cam cover & plug well grommets, you may as well buy the complete upper gasket set from SHO Nut for $140-ish. You get tons more stuff, including the impossible to get otherwise injector o-rings, etc.
