P1121 MAF inconsistent with TPS
Izzmo
SHO Enthusiast
Kansas City, KS
Okay, so I've had this problem, the Mass Air Flow readings are inconsistent with the TPS voltage readins - P1121. Well, I've replaced both the TPS and MAF and yielded no results. I have put the tune back on OEM AWL1 and it still didn't work (I thought it did before but after a quick 10 minute drive it came back).
So, I'm stuck, I have no idea on what it could be now.. any ideas?
Symptoms are it will stall out after coming to a stop, stumble and stall while just sitting in park or drive, seems like it has a rough idle but all the coils have been replaced.
Izzmo
SHO Enthusiast
Kansas City, KS
No, no vacuum leaks.
I did just start receiving P1132 and P1157 now too.. not sure what that means though.
Sam
Fredericksburg, VA
my thoughts
1132: bank 1, cyl 1 overly lean
1157: O2 sensor response to 1132
1121: TPS not set correctly. This appears to be the problem to fix first.
Then reset PCM correctly to clear the codes. (after fix, must clear keep alive RAM, idle engine 15 minutes, drive for awhile - maybe 1/2 hour, to allow PCM to reset)
:sun:
Mr Anonymous
Tire Wall
You have what is called a "rationality" error. The information the PCM is getting from its various sensors isn't making any sense.
Presuming that you have truly verified that there is no un-metered air getting into the engine, then the main components that can cause such an error are a failed TPS, MAF, O2 sensor, or PCM. Based on your lean code I'd either bet a failed O2 or un-metered air getting into the engine. A bad injector or low fuel pressure are outside possibilities as well.
ThatShoGuy
michigan
Can someone take a look at the two data logs in the link below? The first one is me starting up my car and it dying by itself after no run once so ever.
The second is from my driving it around and then dying at a stop light.
Thanks for any help!
Data logs:
http://www.zeroweb.biz/1.csv
http://www.zeroweb.biz/2.csv
i didnt look at the data logs but it sounds like what my car use to do a long time ago.. cant remember is the code was right but the meanin sound the same...
my issue was #8 coil makes some kind of resistant deal on the mafs circuit or something
READ THIS WILL TELL YOU ALL ABOUT IT
http://v8sho.com/SHO/AllSHOandNoGo.htm
this is a video of what my car did... maybe its the same maybe not.. worth a shot http://www.youtube.com/watch?v=DMD2UZEvGH0
try the key on off method i was doing it would let me car run decent for a short period of time...
Izzmo
SHO Enthusiast
Kansas City, KS
Yeah, it's definitely not that bad, but something to that degree does happen sometimes when I'm on the highway.. when it does happen on the highway it feels like it's always in that 'lower gear' in the transmission to slow down faster and will not ever 'snap out of it' until you stop and turn off the car (and by stop I mean it will stall out when you start slowing down, lmao..)
I will try swapping coils #5 with #8 and see if I have a change.
ThatShoGuy
michigan
i noticed you also said you have newer coils maybe try an old coil if you still have them.
Izzmo
SHO Enthusiast
Kansas City, KS
Yeah, actually funny you mention that. I swapped out #5 with #8 and it is all better (still have a miss), so I replaced #5 with an old coil and it works good now.
ThatShoGuy
michigan
lol you owe me a million bucks..:rofl: it took me so long to figure it out and find that info on v8sho.com.
Izzmo
SHO Enthusiast
Kansas City, KS
Well I've known about that problem for a while, but I didn't think it could be it considering how new all my front bank of coils were.. but I guess you can always get shit ones.
ThatShoGuy
michigan
i was trying to figure it out back in 04 when i was like 18.
good luck i hope it fixed your problem happy to help you out!
What brand were the new ones?
I'm guessing they were the chinese ones and not Motorcraft. Only making mental notes of those aftermarket failures. I had several fail and am wondering if that is as common as what I experienced.
Izzmo
SHO Enthusiast
Kansas City, KS
Well I made sure not to buy from China as I've had a few crap out early. The place I bought them from said they manufacture in US, but who knows.
