99sho-time
- Joined
- Dec 15, 2015
- Messages
- 390
- Reaction score
- 97
Alright so I check to see if the smog pump intake tube is moving air it is I also check to see if the vacuum line that pulls air on the check valve was pulling vacuum it was.
Im guessing ether my check valve or the tubing that goes into the manifolds is clogged.
which looks like a crap ton of work.
is there some way to disable it so doesn't require a SAI system via tune someway?
