P0302 help me! (+)
RacerSHO
New York
Hi!
I live in Moscow and I own Taurus SHO V8!
Code P0302 how me to repair the car has lighted up?
Where to climb and what to do?
The engine shivers!
Excuse for my bad English language, badly it I know!;)
Help me please! SHO in Moscow badly know!
Misfire on cyclinder #2. That is the second one from the passenger side fender in the back. Probably a coil.
RacerSHO
New York
| 1 2 3 4 |
| 5 6 7 8 |
(OOO) (OOO)
headlights
I have correctly arranged?
Yes. You should also change plugs, clean the intake, and make sure the rear wires are not melted to the valve cover. usually another piece of split loom is all that is needed to keep the wires from actually touching the valve cover.
RacerSHO
New York
The coil wires run in the loom that goes over the accessory belt, then lay on top of the valve cover with the surge tank on top of them. Over time the tend to stick to the valve cover and may start to short out.
You should change all 4 back coils and save the three that are not throwing a code for future use on the front if needed.
If there is no compression then more than likely the cam has spun bending the valves. Need at minimum a new head or repair the head. Plus a new cam.
RacerSHO
New York
Has ordered coils! I will try to change! Thanks! At us in Moscow of only 5 pieces SHO V8!!! :swing:
