Overheating
Getlow_g
richmond,va
I have a 96 SHO and it overheats alot. I fill up with antifreeze and after I drive about 12 miles it starts overheating and the fluid is leaking from the rear of the engine. What can I do to solve this problem. thanks
yamahaSHO
E85 whore
Arkansas
You say it is leaking from the rear of the engine? Where EXACTLY is it leaking from and how bad?
Getlow_g
richmond,va
It is coming out from behind the oil pan I will have to go out and try to see where it is coming from, plus the oil light comes on and the car started rattling so I turned it off. thanks
Getlow_g
richmond,va
I found where the leak is. It is leaking where the water pump is I don't know if it is a seal or the pump
