Oops, snapped an endlink
Spring Hill, FL
Snapped one of my rear sway bar endlinks yesterday at the bottom bolt, since it technically doesn't have a sway bar in the back anymore just what can I expect the handling to be like? I just need to know so I can compensate before I get the endlinks replaced in a day or so, I just want to be prepared incase inclement weather comes along, thanks :thankyou:
hawkeye18
Sorta cares
Norfolk, VA
It will wallow like a pig and feel scary coming out of corners as the mass transfers to the other side. It will understeer like a champ. Like K-Dawg said, don't corner quickly and you should be fine.
shobote
Naperville, IL
Just go to a parts store like Pep Boys and get new enlinks with bolts; takes a few minutes to replace them. The car is not safe in case you need to make a sudden maneuver. Had that happen once, rear came around and did a 360 when a car pulled in front of me.
Spring Hill, FL
Yea, I'm getting them tomorrow most likely, I just don't have the room here to work on them like I do where I'm going then. So might as well get them done there instead of busting my ass here for twice as long, damned sloped parking spaces. Thanks guys!
