I would clean the MAF and clear the codes. If the O2 codes come back then time for new ones.
Yes... This seemed to fix my problem and the car idled well however after driving around for a while the stall tactics came back. The car starts right back up when I crank it with no difficulty firing or idleing after the stall. This seems strange to me. It was cold and late when I did my 2nd run last night and I didn't test it again afterwards. I'll do everything again and see where I end up. I've got an extra iac/iab from my wreck so I'll try swapping those out as well. Can't hurt. I did muck with that throttle body set screw a ways back. What does that thing do and how do I ensure that it's correctly set?sdpatt:
haydenm315, have you reset the idle speed?
Thankssdpatt
[QB]The base idle speed is set with the set screw at 850 rpm with the IAC valve disconnected and the SPOUT plug pulled. You can probably get away with just pulling the IAC connector. This allows the IAC valve a good working range.
I dont' think so. I ran the car until it stalled after resetting the idle. Upon restarting after the stall the idle is fine until I start to slow down again, take it out of gear and try to idle.If the idle reset corrected the problem for a
short time, was it until the engine was stopped?
So 10/10 times the problem lies between the connector and the sensor for the cps when that pip code is thrown. I have problems trusting computers since I work with them and know how they act. I dont' feel like going down there in the freezing cold if there is a possibility of it being something else that can be checked first before trudging down there again.sdpatt:
The PIP (profile ignition pickup) is the crankshaft position sensor (CPS) on the SHO.
Contrary to what everyone has said I went ahead and increased the throttle body set screw a little bit and reset my idle again just for grins. The car idles fine and hasn't shown the stall when approaching idle problem yet. Once it did dip to 500rpms but it didn't surge and then die like it previously did. I still need to run my codes again to see if anything is still running rampant. I also replaced a damaged - battery terminal clamp which caused my car to quit and not restart in the recent past when pulling into a parking spot.sdpatt:
If the idle reset corrected the problem for a short time, was it until the engine was stopped? That could mean that the keep alive memory power is not maintaining the ECC memory. Is there a second, smaller wire connected to teh negative battery terminal? Follow the wire and make sure the connector is still plugged in.
