One coil not firing. DIS bad?
Spork
Gainesville, FL
The coil for the #2 and #6 cylinders is intermittently not firing causing my 91 to run rough. The tach needle will bounce around when this is happening. I replaced the aftermarket coil pack with the original Motorcraft pack I saved and have the same problem. I'm thinking it could be the DIS module. How can I verify this is the problem before I spend a bunch of money on a new DIS module?
kevinspann
Don't take my advice.
Richmond VA
Auto parts store will test a DIS - but good ones can fail that test. Is the DIS broken in any way? How are your motor mounts? I would check the wiring to the DIS and to the coil, since your issue is intermittent.
Spork
Gainesville, FL
The DIS isn't damaged. Mounts are fine as far as I know. I just removed the DIS connectors to check for corrosion. After re-seating the connectors, I fired it up and it runs fine. Go figure.
Spork
Gainesville, FL
Started fine this morning, but was sputtering before I could roll out of my driveway. I tried cleaning the contacts on the DIS module with no luck.
kevinspann
Richmond VA
Temperature related by chance? I would still take a look at all of the wiring.
And see what kind of codes are stored in the PCM.
gurucomputers
Everett, WA
Just had the same issue with my 94. Has code 216 "Coil 2 primary circuit failure" replaced DIS and haven't had any problems since.
Spork
Gainesville, FL
I got the coil primary circuit failure code as well. I swapped the coil so I figured I misread the code. I guess I'll but a new DIS module as I seem to have ruled out other suspects.
