Spork
The coil for the #2 and #6 cylinders is intermittently not firing causing my 91 to run rough. The tach needle will bounce around when this is happening. I replaced the aftermarket coil pack with the original Motorcraft pack I saved and have the same problem. I'm thinking it could be the DIS module. How can I verify this is the problem before I spend a bunch of money on a new DIS module?
