Once and for all...oil pressure sender!!!
Goulash
Urbana, OH
OK, I bought an oil pressure gauge, a pipe tee, and a new pressure switch, and would love nothing more than to install them, but I can't find the switch! I've searched and searched, and everyone says it's on the block under the rear head, close to the driver's side, but I can't see it. Is there any trick to finding this thing? Should I remove a part? Is there a suggested angle? Any help here would be appreciated...
It's a 93 ATX, if that makes a difference, and I have the y-pipe dropped for my upcoming rod bearing job. Thanks in advance...
- Justin
K-Dawg
Treasure Coast, FL
Correct, it is on the firewall side of the block, driver's side, just under the head. With the y-pipe dropped I think you should be able to see it or access it on an ATX. Somewhat hard to get to, but it can be done. It only has one wire connected to it.
crystizel
