Brians_VT_SHO
My SHO has been driving me nuts. I don't know if I have a plugged Cat, Plugged fuel filter, cooling problem or what...........
I'll start from the beginning. Last Fri night I was driving my SHO when I smelled hot grease, I pulled over, opened the hood and found fire coming from the area of the right inner CV boot. It went out as quick as it started but the Boot failed and dripped grease on the Right cat. I towed it home (at this point I'd owned the car less than 48 hours) after a search I finaly found a boot kit that would fit it. I took it for a quick test drive and when I pulled over to check on the boot, I found the right Cat glowing red hot. I drove it back home slowly. I have also noticed that the temp gauge never gets above the L in Normal. Assuming I had the run cool, run rich/overheating cat problem, I pulled the thermostat and found it to be in perfect working order (checked in a pan of water with a thermometer, opened at 190 deg.) put it back together, still have glowing cats. Also it's running rough now
I called several shops and asked them what they thought. I got answers all over the place from a plugged fuel filter to plugged cats to a stuck on fan to jumped timing.
I'm about ready to put this puppy up for sale here pretty quick (along with the parts car with the bad ATX)
As it is I'm calling the state about the guy I bought it from. He's been no help at all, and since VT has an implied warranty law, I may be able to get something done.
Soooooo, does anyone have an idea where I should start looking for things to check so I can get it back on the road?
Thanks
Brian
Thanks
Brian
