OK I WILL TRY THIS AGAIN
FASTSHOMTX92
NEW YORK
Ok i just put a use tranny MTX in my 92, I cannot rev out 1st gear and slam 2nd past 4 1/2 grand. I will rev out at arout 7 1/2 grand press the cluch in and it will stay in the neutral position until the RPM's drop down too 4 1/2 grand and than it will ingadge into the second gear position and sometimes the cluch will not even grab, the engine will be racing but the car ait moving like it should sometimes. I also just put a 450$ cluch in it too. I cannot find a adjustment, does anyone have an idea or am i not seeing the adjustment or do i have a problem plese help?
It's SHO Time
Gillette, Wyo
in order to adjust the clutch you make sure the car is off and in neutural and pull up on the clutch pedal with your hands till you hear a click and then press is all the way down with your foot and if your clutch cable was out of wake then you'll hear it click again. hope this helps,
Justin
