Ok i got a noise in the front.
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
I have a noise in the front of my car and when i turn the steering wheel. it mkaes like a chucking noise or grinding noise. So my bro works at ford and he told me to have them look at it. he took it in and they said this.
Needs New rack and pin -$525.00 (which i new that i new my steering was messied up before i went in there but the noise is new)
sway Bar Links-165.00
and Front end alimant-43.00
i was wanting to know is that a good price or not?? and i was wondering sicne they ould be tinkering with the sway bar should i go ahead and get the 24mm and 26mm i think that is right. I have been away from the forum for along time. I have been really busy lately!!
So any help here will help guys!!
Brad
93 Sliver ATX
SS cold air snorkel with k&n fliter, superchip, flowmasters 40 series, pp y-pipe, Performance Friction Carbon Metallic Brake pads, Pilot fog lights, Intake Painted sliver, Kenwood excelon cd player and 10 dics changer. 5% tint all around! Ford Motorsports decal on windsheild, and Blue sho reflective lettering on the body.Blue, Yamaha inside stickers. Blue, SHOForum.com sticker on back window. Ford emblems on my back triangle window with racing decal under it. So it says Ford Racing!! Indy Tags: SHODU
Looking for a Sliver or Black MTX with low miles!!!
The noise you described gets to be more of a problem as the weather cools off. The SHO definitely has a problem with the upper front spring pad which is thick rubber, rubbing against the inside of the strut tower. This can be due to moving the top of the struts outboard to get the camber in spec, especially with Eibach springs.
A simple fix is to apply some silicone grease (Syl-Glide) to the inside of the strut tower with a rubber gloved hand. The interference point is usually in the forward, outboard area of the tower. If you take the wheel off and look up inside, you may even see where the paint has been worn off. You can reach this area with the wheels on by turning them full lock in each direction. I have to reapply the silicone about every 4-6 months and it only takes about 2 minutes.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
RStalveyARFF
too many shos
Georgetown, MA
There's just one problem.... They don't make new Rack and Pinions for the SHO anymore. Better have them re-estimate the repairs. Sway bar links for the front are 25 each I believe from sho-nut, and the rears can be had in polyurethane from any autozone for 10 dollars for a pair.
[This message has been edited by SHO91MTX (edited 11-29-2001).]
