ViPER1313
1. Should the sensor bottom out on the block? The old sensor I replaced only had the first 4-5 threads engaged (where the red sealant is located on the threads.)
2. If the sensor is supposed to have all threads engaged, what should the sensor be torqued to?
3. Is there a special tool to screw this thing in or will a 5pt 1 1/16in deep socket work (my 12pt 1 1/16 does not work.)
